Back to Life - Ready for another 65 years
I declare victory re my 46-1213 project. Cabinet restored to mint condition, stripped the top layer of plywood and replaced with a 1/4 piece of walnut, carefully glued and refinished. 100% original look. Chassis re-capped and a top-to-bottom alignment, FM, AM and SW. All system work fine. Record changer re-furbished by Gib of West-Tech.
Thanks to all, I do appreciate your help.
Now I must ship it to Florida. Yikes .. Icon_redface Icon_redface Icon_redface ..... the thought of it.
Now lets see, where were we , oh yes, next, the 50-1723.
The 50-1723 should keep you busy for an hour or two.
Hope your move goes well without any damage.
The speaker table error?
Philco 70 antenna lead
There are currently 6905 online users. [Complete List]
» 1 Member(s) | 6904 Guest(s)
