zenith 6S632
I am finishing a 6S632. I was wondering if anybody has a good picture and if the bottom stripe is photo finish or veneer.
Mine is gone whatever it was.
Thanks
Jim
Here's one
http://www.radioatticarchives.com/radio.htm?radio=3627
