Emerson DA287 Resistor Question
I'm in the process of restoring an Emerson DA287 and have a real head scratcher question. Riders shows ( http://www.nostalgiaair.org/Resources/019/M0005019.htm ) resistor "R7" to be 15 mega ohms.... I've never run across a resistor that I can remember to be of that high a value! It's burnt and needs to be replaced. I checked on the AES website and the highest value they even list is 8 mega ohms. Wondering IF this could be a misprint and if not, shouldn't the 8 mega ohm work OK? The largest value resistor I have in my box is just 1 mega ohm. Ideas - thoughts??
Here you go.
http://www.mouser.com/ProductDetail/KOA-...LkE5hIs%3d
15 megohms, 1/2 watt, from Mouser Electronics....and only 34 cents Icon_smile
There are currently 8406 online users. [Complete List]
» 1 Member(s) | 8405 Guest(s)
