01-19-2012, 08:09 PM
Is there a way to get the transformer specs from the Philco part number?
Thanks
Thanks
Philco Power Transformers
Thanks
01-19-2012, 08:44 PM
Yes there is. Let me know the PHILCO part number on the shell, which will start with a 32-xxxx or jusr four digits.
I have Philco Parts Catalogues from the about the mid-30s to 1945. There are some already on my website in the Parts Values section. Regards, Chuck Chuck Schwark, The Philco Repair Bench [Image: http://www.philcorepairbench.com/images/philog3tiny.gif] http://www.philcorepairbench.com
01-19-2012, 09:06 PM
I need one for a 38-1. The print lists part as 32-7889
I found one in a junk chasis part 32-7597N. I would like to find specs to see if it will work. Thanks for you help. Jim
01-20-2012, 12:30 AM
Jim,.
No, unfortunately, it won't work. The correct p/n is actually 32-7869, not 7889, for the Model 38-1. The HV secondary of the 32-7597 only rated at 100 ma. The 32-7869 HV secondary is 160 ma. Also the correct transformer filament current is 6 amps, and the fil amps on the 7597 is only 3 amps. Here are the full electrical specs for the correct 32-7869 used in the 38-1 (ALSO 38-2). Primary = 110-120 vac Secondary = 660 vac @ 163 ma. Fil = 6.7 vac @ 6 A. Rect = 5 vac @ 3 A. (Rect tube socket mounted on top shell) Chuck Chuck Schwark, The Philco Repair Bench [Image: http://www.philcorepairbench.com/images/philog3tiny.gif] http://www.philcorepairbench.com
01-20-2012, 08:04 AM
Thanks for you time and the correct part number.
My eyes are not as good as they were. Thanks Jim
« Next Oldest | Next Newest »
Users browsing this thread: 2 Guest(s) |
