Hi Everyone !
Hi - I'd just like to introduce myself as a new member - I have only been working with old radios of other makes for the last 6 months or so and am just tackling my first Philco - a type 610 tombstone. In spite of the fact that its been hacked around a fair bit as you'd probably expect, I'd have to say that I'm really impressed with its solid construction and design. I hope I can do it justice.
I can see that I have my work cut out for me this time, but all the important basic stuff - transformer and field coil etc are looking good so hopefully I'll get there in the end. Underneath all the gunge and fluff, the transformer looks almost like new - amazing really.
Anyway, my compliments on a great forum and thanks for the information posted here which has already been a lot of help - I reckon I can tackle those mysterious-looking bakelite cap blocks now !
Chris
Hello, and welcome! The 610 is a good set to begin with. They are a pretty good radio when working right! With a good antenna you should easily pickup many distant broadcast and shortwave stations....
Hi!
-Bill
Welcome. You'll have a nice radio soon!
Hey Chris and Welcome to the Phourm!!!
The 610 is a great set for your first. Pretty simple and it has no rubber wire or photo finish. Lots of repro parts available for it like the dial and knobs. Keep us posted with your progress and we'll guide you along when you have a question. Nice set from 1936.
Hi and Welcome to the Phorum!!!
Gene
Hello Chris and welcome!
Good luck on your 610, if you have any issues, or are unsure about doing something, let us know.
Welcome aboard. Just in case you or anyone else doesn't realize it, Chuck has a separate Philco site. Between him and Ron, the world of Philco is at your finger tips.
http://www.philcorepairbench.com/
Welcome to the wonderful world of Philcos! Icon_thumbup
Philco 91 Tuning Condenser
There are currently 5593 online users. [Complete List]
» 1 Member(s) | 5592 Guest(s)
