  • 3 Vote(s) - 1.33 Average
Magnetic tuning and Shadowgraph
Was the 37-116 standard model the only model to use these features together? The last shadowgraph was in '37 it was dropped for the '38 models right?
Hi Terry
The 37-675 Standard also used a shadowmeter and Magnetic Tuning, but no automatic tuning mechanism.
There were some 1938 models that used a shadowmeter. None of these had Magnetic Tuning, though.
Philco 91 Tuning Condenser
There are currently 5779 online users. [Complete List]
» 3 Member(s) | 5776 Guest(s)
