Philco 1934 Model 60mb
Can Anyone tell me if there was ever a home users manual and service/repair manual for this model 60mb (modern baby grand), I cannot find one anywhere, i've hunted the net for weeks and nothing, any help would be truly appreciated especially if any one has a copy of the Home Users Manual
Hi and Welcome to the phourm!
Here's the service info for the model 60.
http://www.nostalgiaair.org/Resources/793/M0013793.htm
(02-26-2012, 11:50 PM)7estatdef Wrote:  Hi and Welcome to the phourm!
Hi Terry,
Thanks so much for this service info ! Do you happen to know if there would have ever been an instruction book for the owner of this radio?
Truly
Dave
Also, look here. http://www.philcoradio.com/tech/60evol.htm
M R Radios   C M Tubes
(02-27-2012, 02:52 PM)Steve Davis Wrote:  Also, look here. http://www.philcoradio.com/tech/60evol.htm
Thanks Steve! This was interesting and helpful
Dave
Hi Terry,
Truly
Dave
There was a 1 or 2 page paper that would show you how to operate the set but it was gotten rid of 80yrs ago. Most folks could figure how to work it without the instructions
Hi Terry,
Truly
Dave
That explains why I cant find one then!
Just would have been nice to have seen it though.
Dave
Philco 91 Tuning Condenser
There are currently 5807 online users. [Complete List]
» 3 Member(s) | 5804 Guest(s)
