Maggy Regency Symphony manual dwnld
Here are images of an original price tag for a 1947 Magnavox Regency Symphony 155-B as well as a link to download a PDF copy of the original operating manual.
Link for manual:
http://www.enter.net/~rocketeer/radio/maggy 155B.pdf
If you print these images on oaktag at their original size, you can cut them out and make a hangtag for your display.
[Image: http://i863.photobucket.com/albums/ab191...etag-1.jpg]
[Image: http://i863.photobucket.com/albums/ab191...etag-2.jpg]
Larry
Larry
Thanks very much for posting these! Icon_thumbup
There are currently 8410 online users. [Complete List]
» 1 Member(s) | 8409 Guest(s)
