Picked up a 610F console today
Got this off Craigslist. It's a pretty small console.
[Image: http://i1129.photobucket.com/albums/m501...96672d.jpg]
[Image: http://i1129.photobucket.com/albums/m501...d7e655.jpg]
[Image: http://i1129.photobucket.com/albums/m501...8b76c7.jpg]
[Image: http://i1129.photobucket.com/albums/m501...169a02.jpg]
[Image: http://i1129.photobucket.com/albums/m501...b4e955.jpg]
-Keith
Congratulations on your acquisition!
Every 610 model that I have ever had/worked on was a lot of radio for a five tube set! Nice find!
Nice one!!
Going to be downright Snazzy when you get done, I'm sure.
Philco 91 Tuning Condenser
There are currently 5980 online users. [Complete List]
» 3 Member(s) | 5977 Guest(s)
