42-123 output trans. replacement
Does anyone know of a replacement output trans, new or interchangable from another model that would work in a 42-123? 900/1100 CT.
Thanks, Todd
Those 1LA4's have a very high plate impedance. 25K each so what you are looking for is a transformer 50K ct to 8 ohms
The speaker table error?
Philco 70 antenna lead
