Philco model 65
Hi
Any one out there have a model 65 philco chassis and speaker? This is most likely a shot in the dark, but I know where a 1929 model 65 cabinet is, alto it has no chassis or speaker in the cabinet Icon_sad . The cabinet is in good shape. So if anyone has one and will part with it reasonably Icon_smile I am interested. I think the chassis may have been used in the model 30, 41, 77 and maybe more but not sure. Thanks
Joe
If its the lowboy with the scallop grill you could also use a 95 chassis.
87 would work too if the 95 does.
You can probably make most of the chassis/speakers work that had the old knob arrangement like your 65. Main diff would be the 111/112 and model 15 chassis, reason is the dial scale is wider and is blocked out by the narrow-er escutchion window.
Philco 91 Tuning Condenser
There are currently 2745 online users. [Complete List]
» 1 Member(s) | 2744 Guest(s)
