Whats this?
Model?
http://www.ebay.com/itm/Vintage-Philco-R...4cffc8f837
Model 52C:
http://www.philcoradio.com/gallery/1932b.htm#r
(04-02-2012, 08:31 PM)Ron Ramirez Wrote:  Model 52C:
Thanks Ron
I have one that I re-capped and refinished a few years ago. he one in the eBay auction has some sort of nondescript grille cloth in it.
Cute set, but not one of Philco's more impressive sets. It's a TRF, if memory serves, and not as good as it looks.
(04-02-2012, 11:38 PM)Doug Houston Wrote:  I have one that I re-capped and refinished a few years ago. he one in the eBay auction has some sort of nondescript grille cloth in it.
I thought it was interesting looking and suspected TRF.
Thanks much
Philco 91 Tuning Condenser
There are currently 6001 online users. [Complete List]
» 2 Member(s) | 5999 Guest(s)
