Scored a 41-316RX !
#31
I'm in the home stretch on the cabinet. This bottom area was so bad (probably from years of getting kicked) I decided to replace the veneer.
[Image: http://farm8.staticflickr.com/7278/68968...a49670.jpg]
That should do it.
[Image: http://farm8.staticflickr.com/7060/70429...b9af70.jpg]
#32
Great job as always... Icon_thumbup
I haven't started working on the electronics yet, but I did just find an original Philco BB30-12P battery. I'm pretty sure it's the type used in the Mystery Control. The plan is to replace the insides with modern batteries and use it in the remote.
[Image: https://c1.staticflickr.com/1/497/189365...7da9_c.jpg]
#34
Cool Battery Icon_biggrin
There are currently 3712 online users. [Complete List]
» 1 Member(s) | 3711 Guest(s)
