Philco 118H Cabinet, Question for Ron
Threads: 11
City: Black Mountain, NC
I have a Philco 118H that needs some TLC. The cabinet veneer appears to be OK, just needing cleaning and condition.
My question to Ron, keeper of the Philco Furniture History book...
The legs on mine have a few pieces that came off the legs. The veneer on the stringers as well is peeling and missing from dampness it was exposed to.
What wood are the legs made from?
What is the cabinet finish/toner color used?
What was the veneer on the stringers?
Posted here rather than a PM so others, including "glennpr" can benefit.
Thanks in advance.
Mike
Cossor 3468
GE 417A
Philco 118H
Radiola 17/100
Scott 800B6
Silvertone 6130
Stromberg 535M
Truetone D1952
(This post was last modified: 04-27-2012, 12:18 PM by PhilcoMike.)
At work so will have to answer the wood type later...
"a few pieces that can off the legs"? I think you mean came off the legs?
As I recall from the one I had previously (which glennpr now owns) along with one or two others I have seen, I think Perfect Brown would be good for the cabinet overall - something a bit darker than Medium Walnut, but not a lot darker; and it needs to be an "Ultra Classic" product so you don't lose the woodgrain. The front panel originally had a "sunburst" look with the majority being Medium Walnut, with Perfect Brown around the edges. Just take a look at any of the radios being sold by Arran's favorite eBay seller "Foggy", and you will see what I mean - only this effect is on the front panel alone, not on the edges of the cabinet.
Threads: 17
City: Yorkville IL
(04-26-2012, 11:52 AM)Ron Ramirez Wrote: At work so will have to answer the wood type later...
I attached these again. If you need any additional pictures just let me know.
Glenn
http://s1230.photobucket.com/albums/ee48...18left.jpg
http://s1230.photobucket.com/albums/ee48...18full.jpg
http://s1230.photobucket.com/albums/ee48...8front.jpg
Happily back in Illinois..not.
OK, I have the book in front of me - and, unfortunately, it does not mention the types of wood used.
Looking back, I see Furniture History stops mentioning the types of wood/veneer used after early 1933. Sorry.
The veneer on the top and sides will be some sort of walnut. Exactly what type, quarter-sawn, half-sawn, full-sawn, sawn-shawn, I don't know.
Here are Glenn's photos.
[Image: http://i1230.photobucket.com/albums/ee48...18left.jpg]
[Image: http://i1230.photobucket.com/albums/ee48...18full.jpg]
[Image: http://i1230.photobucket.com/albums/ee48...8front.jpg]
I think I misspoke when I described the toners. It looks like it uses either Maison Brown (Ultra Classic) or Extra Dark Walnut (Tone Finish) on the trim pieces and possibly the legs, with Perfect Brown (Ultra Classic) overall otherwise. I think these tended to be a little bit darker overall than sets using Medium Walnut.
Threads: 17
City: Yorkville IL
(04-27-2012, 05:38 AM)Ron Ramirez Wrote: OK, I have the book in front of me - and, unfortunately, it does not mention the types of wood used.
Thanks for posting those...I tried but gave up. Seeing these pictures has me re-motivated to finish the shadowmeter coil winding and get the chassis back together and in this cabinet.
Glenn
Threads: 11
(04-27-2012, 06:17 AM)glennpr Wrote: (04-27-2012, 05:38 AM)Ron Ramirez Wrote: OK, I have the book in front of me - and, unfortunately, it does not mention the types of wood used.
Glenn
Thanks Ron, Glenn,
You two are my Philco 118H Heros!!!
Mike
Cossor 3468
GE 417A
Philco 118H
Radiola 17/100
Scott 800B6
Silvertone 6130
Stromberg 535M
Truetone D1952
Philco 630csx power cord
Have you opened up that plug? It may be that the third wire is connected to that brass stud on the side of the plug and ...Arran — 02:57 AM |
Model 27-84 BUZZ?Humm?
I would have to look at the schematic but it's not uncommon in 1930s AC radios to have the negative of one filter cap co...Arran — 02:46 AM |
Hello Bruce,
First all do mean a 37-84b ?
Did you take any before and after pictures ?
is it a buzz like when you touch...radiorich — 01:59 AM |
Hello Tim,
Yes, I even check all of my replacement parts when I install them and I too had a capacitor go bad not long a...radiorich — 01:54 AM |
I got back into it tonight. Problem found and resolved! Sometimes it helps to take a break and think things over. It was...TV MAN — 12:40 AM |
Thank you. I have to take a break from it for about a week. I'll have to do some thinking. I was toying with the idea ...R3Sons — 12:21 AM |
Drowning in a overloud buzz/Humm. Have already changed filter caps,bakelite blocks( caps),out of speck resistors,checked...Bruce — 12:17 AM |
Hello Mike
Here is the Link to the company the place is called Grand Brass lamp parts .
I buy all my Lamp parts plus ...radiorich — 12:00 AM |
Is the tube in your radio actually 35Z3 or 35Y4, or something else?morzh — 10:55 PM |
Second Rich's opinion.
Run a separate antenna wire. Use a separate plug.
Rich
Where did you get this wire? Se...morzh — 10:51 PM |
There are currently 2179 online users. [Complete List] » 4 Member(s) | 2175 Guest(s)
