Growing up quick...with a 38-690xx Pics added.
Threads: 2
I have been a busy bee. Honing my skills and learning as much as I can. My little Model 20 consolette just got a big brother! A 38-690 has found it's way into my very happy hands. I will be taking my time and doing this one right. All caps and lytics will be re-stuffed to preserve the original appearance under the chassis. All tubes that need replacing will be Philco branded. Proper cloth wire where needed etc etc. This set is completely original from what I can tell. Its extremely dirty and the amp chassis has some exterior rust issues but nothing terrible. It is complete and the cabinet is solid although the original finish is unfortunately too far gone to save. I'm gonna need help guy and girls. Any and all tips and tricks or advice is greatly appreciated. I know the importance of this console in Philco history and want to treat it right. Thanks!
(This post was last modified: 05-03-2012, 12:40 AM by badwaxcaps.)
Threads: 18
(05-01-2012, 12:52 PM)badwaxcaps Wrote: I have been a busy bee. Honing my skills and learning as much as I can. My little Model 20 consolette just got a big brother! A 38-690 has found it's way into my very happy hands. I will be taking my time and doing this one right. All caps and lytics will be re-stuffed to preserve the original appearance under the chassis. All tubes that need replacing will be Philco branded. Proper cloth wire where needed etc etc. This set is completely original from what I can tell. Its extremely dirty and the amp chassis has some exterior rust issues but nothing terrible. It is complete and the cabinet is solid although the original finish is unfortunately too far gone to save. I'm gonna need help guy and girls. Any and all tips and tricks or advice is greatly appreciated. I know the importance of this console in Philco history and want to treat it right. Thanks!
Wow, this is one complicated set.
You might want to get a decent schematic set from Chuck's website
http://www.philcorepairbench.com/schematics.htm
Because the one on NA is pretty blurry.
http://www.nostalgiaair.org/Resources/255/M0013255.htm
Threads: 2
Pulled all the tubes last night and found some good and some bad. Unfortunately both 6L6G's tested rather weak. I have begun taking high res digital pictures of everything for reference and started a notebook for documenting progress and such. I have seen a couple of articles on re-stuffing paper caps but was wondering if anyone has any advice on what works best.
Congratulations on your acquisition!
Just remember, do not disturb the single bakelite block in the upper chassis, part (97). That does not - repeat, does not - contain any capacitors. Instead, it contains the coils for the 10 kc audio filter! Leave it alone.
Threads: 2
Thanks for the heads up on that "cap" block Ron. I would have been sorry after chipping its insides out! Another question.. I believe the original woofer cone is in fine shape but it was recommended that I have it reconed anyway to get the best possible sound. Do I really want to do that or retain the original. I want the best possible sound reproduction but not if its going to detract from the value or originality of the set. If the speaker is shot then I can understand a recone job but what if its pristine?
(This post was last modified: 05-02-2012, 05:16 PM by badwaxcaps.)
No!
Unless there is a problem with the original cone... leave it alone. Believe me, the originals sound just fine, thank you.
Threads: 2
Believe me the last thing I want to do is change anything. I blast people out of the room with my 10S669 Zenith and it has it's original speaker so I will definitely retain the cone on the Philco if its in decent shape. It is composed of two different materials. Whats the significance of that design?
Threads: 2
![05-03-2012, 12:36 AM](attachment.php?aid=868)
Here are some pics of the tuner chassis. If they come out properly. As you can see I have my work cut out for me.
(This post was last modified: 05-03-2012, 12:39 AM by badwaxcaps.)
Threads: 2
(This post was last modified: 05-03-2012, 12:47 AM by badwaxcaps.)
Threads: 2
City: Sedona, AZ/Placentia/CA
BWC, looks like someone tried to "reform" one of those electrolytics. ![Icon_crazy Icon_crazy](https://philcoradio.com/phorum/images/smilies/icon_crazy.gif) Due to holiday, your caps will mail out today. Those sockets don't look too bad. I would carefully realign the bent pins and hit the fiber board with crazy glue. If you want to go nuts, mix up a little epoxy and fill in where part of the board is missing.
Jerry
(This post was last modified: 05-29-2012, 01:32 PM by jerryhawthorne.)
Threads: 18
Preserve as best your "umbilical" plugs and sockets. Wire can be replaced, but plugs and sockets, that's another story. Agree replace, restuff, whatever all the elecrolytics and paper caps at a bare minimum before even thinking about bringing set up ever so slowly with variac.
Threads: 54
Quote: Is there any chance of obtaining replacement umbilical plugs? Somebody (not me) broke these. Probably prying them out of their sockets with a screwdriver.
There may be source for similar plugs elsewhere but I wouldn't count on finding them as they were likely proprietory to the Philco 690s and maybe only the 38-690s. Most of the two chassis sets I have seen use a 7 pin plugs and sockets to tie the cable to the chassis. I would take the plug apart and try gluing and filling the wafer back together with two part epoxy, preferably high heat epoxy without metal fill in it (do not use metal filled JB Weld) you may have to clean the phenolic material up good before you do. If it's really bad you may have to make a duplicate of the original wafer and replace it altogether.
Threads: 2
I found some suitable material to reinforce the existing wafers. That "reformed" lytic has been straightened and restuffed. I managed to clean up the mangled shield bases and they will now accept shields correctly. Now all I have to do is locate two shields
Threads: 92
City: Clayton, NC
Keep up the good work!
Make sure th eperson who answered is not a scammer (lots of these there now) and the Trus A S, whoever they are and wher...morzh — 12:38 PM |
I would disregard everything that is there now. I do not know who and when changed it.
1. Make sure that what you thi...morzh — 12:36 PM |
Model 27-84 BUZZ?Humm?
Depends on the type of hum. SOme is made by outside devices.
Try installing an X-cap (0.2-0.5uF) across the AC line, ...morzh — 12:23 PM |
Thank you for your replies.
That is the correct schematic and pin out diagram for the rectifier. The resistance acro...bluecap — 11:01 AM |
Late last night a guy reached out in response to my posting on the Antique Radio Forum and suggested I contact Trust Aut...jrblasde — 11:01 AM |
Philco 630csx power cord
Have you opened up that plug? It may be that the third wire is connected to that brass stud on the side of the plug and ...Arran — 02:57 AM |
I would have to look at the schematic but it's not uncommon in 1930s AC radios to have the negative of one filter cap co...Arran — 02:46 AM |
Hello Bruce,
First all do mean a 37-84b ?
Did you take any before and after pictures ?
is it a buzz like when you touch...radiorich — 01:59 AM |
Hello Tim,
Yes, I even check all of my replacement parts when I install them and I too had a capacitor go bad not long a...radiorich — 01:54 AM |
I got back into it tonight. Problem found and resolved! Sometimes it helps to take a break and think things over. It was...TV MAN — 12:40 AM |
There are currently 3383 online users. [Complete List] » 3 Member(s) | 3380 Guest(s)
