Restuffing a thin long cap.
Threads: 562
I have a Zenith electrolytic that is totally dried up (says 16uF 400V, measures at 1nF and is suspiciously lightweight), and that is very slim and long (under 1" diam. and 5.5" long).
I want to restuff it but not sure where best to cut it. I want it to look undamaged when it's done, but if I cut the top, I simply won't reach to the bottom. Too long and narrow. If I cut the bottom, it will look like you know what.
Anyone has experience dealing with those?
I had no problem with those that were twice as wide, but this one's a challenge.
PS. How do I connect the Negative wire to the aluminum body? (soldering won't work on aluminum.)
Threads: 18
Don't seem to be problem replacing a modern 22 mf/450 VDC electrolytic in it's place. Just observe polarity. Forget about stuffing old one unless you are working in a museaum. Negative almost certainly would be "body" but trust the schematic and original connections.
Threads: 562
![05-16-2012, 07:57 PM](attachment.php?aid=928)
Codefox,
Well, I know that, about polarity and such.
I really want this cap in this radio, and this is the sole purpose of this post.
Here is the cap.
Threads: 55
City: Lexington, KY
I would first try going in from the top. Using some small long needle-nose pliers and hemostats you should be able to gut the thing and slip in the new cap and fish the leads out the bottom.
If you can't do it from the top I think if you make a thin/clean cut close to the bottom it will not look that bad when reassembled. You can find or fashion a small tube to slip both the top and bottom over and glue/epoxy them together.
I would insulate both leads and run them out the bottom and then connect the applicable one to ground under the chassis at a convenient location.
Worst case scenario would be to leave the old capacitor on the chassis and mount a new one underneath. That's the way an old repair shop would have handled it, and you could even stuff the new cap into an old axial electrolytic for a period correct looking repair. Just a couple of ideas for you to think over.
Threads: 562
John,
Thanks, yes, the axial electrolytic is not a bad idea.....provided I can get me one of the old.
As for the two insulated wires out, you probably mean something like this?
Those had insulated body and two wires and this is how i re-stuffed them; I can make this one look like it too.
Actually this is an even better idea, as the length precludes me from soldering to the center pin, but if I don't need it and am out to simply gut the cap and remove the center pin, it requires no finesse and can be done even with this length to width ratio.
Thanks, I think I know what I'll do.
It pays to discuss things.
Threads: 562
I will post photos either today or tomorrow: I cut off the top cap with my Dremel and the cutting disk, right at the groove, so it will look fine.
Insides were as dry as H**l on a hot day in June.
Taking them out did not pose any problems, and there was no tar or anything. It was dry dry.
The central rod is quite high and should it be solderable I'd have no problem soldering to it, but I think it is not, and it is attached to the solder contact with a rivet of some sort.
So as I planned, I will remove it and go with two wires.
I will wait 'till I finish, but so far it is not nearly as bad as I thought it would be.
Threads: 18
Threads: 562
Oh Me lave los manos, sin duda. Load of dust and who knows what else.
But then any opened electrolytic commands the same handwashing: wet or dry, it is all possibly very toxic if ingested.
PS>
Here, I made some pics.
Philco 91 Tuning Condenser
Hello,
Does anyone know how the dial plate comes off the tuning condenser shaft? The dial itself id so warped I can't...dconant — 06:01 PM |
Ron,
for the future:
1. Go to the very first post.
2. Hit "Edit...morzh — 04:29 PM |
Transistors are easy.
Or touch your fin...morzh — 04:25 PM |
Hi Mike, I believe I tried different ways to change the header for my post but no luck. Anyway thanks for changing it fo...462ron — 04:02 PM |
Since these radios operated in harsh environments (temp changes and vibration) you could touch a soldering iron to all t...GarySP — 03:18 PM |
Thank you Gary. Hi Morzh. These radios are 6 transistor radios. Sadly no tubes. Thanks though.R3Sons — 02:19 PM |
Ron
Instead of Quick reply, go to New Reply, then go to the title of the very first post, and change the title text the...morzh — 02:00 PM |
I am not a specialist in car radios.
I suspect they might use vibrators to convert 12V to acceptable tube voltages, so ...morzh — 01:58 PM |
Welcome to the Phorum, R3Sons! I have very limited experience with car radios other than installing custom radios back ...GarySP — 01:08 PM |
OK, I need to rename this thread to say..Eico 368 TV/FM Sweep Generator instead of the current title..Heathkit Sweep Gen...462ron — 12:49 PM |
There are currently 8715 online users. [Complete List] » 3 Member(s) | 8712 Guest(s)
