6 meg pot needed?
I just re-capped a Philco 48-1263 and it sounds pretty good, but I have a question about the switched pot for on/off and tone control. It had obviously not an original one on it, the schematic calls for a 6 meg and this was a 500k. There was no tone variance and also it smoked now and then, pretty scary to me. I stuck a new 1 meg on it and no more smoking, but there is still no tone variance. I assume that I do need a 6 meg pot, nothing less. Where will I find such a thing? Only by cannibalizing another radio? As always, thanks so much for your knowledge guys.
Alan
That, or by contacting Mark Oppat:
http://www.oldradioparts.net/
Thanks for the reply Ron, I've sent a message off to Mark Oppat. Does it make sense that I won't have a tone variance without the 6 meg?
Alan
Well I'd have a look at C205. Ground the end that goes to the pot. If all is well it will reduce the high frequency response. If not replace it.
Philco 70 antenna lead
Thanks Arran; I don't even know what a double conversion is, but i do have a good friend In Nova Scotia that would k...Dan Walker — 07:01 PM
Dan; I've seen some Marconi sets like that before, one was a console though I'm not sure if it was a model 86. It's a...Arran — 05:09 PM
Milkjug plastic? Whatever is chosen for the spider, the material must be compatible with popular adhesives... Th...Chas — 05:05 PM
There are currently 3261 online users. [Complete List]
» 4 Member(s) | 3257 Guest(s)
AvatarAvatarAvatarAvatar
