Practical Battery Operation
Hi, I've been given a model 41-95 code 121 for a present .I have not even taken a good look at it yet. Here's the question.Is there a battery that can be purchased or ganged together that is not a bunch of small cells ? I want to use this radio in a spot where there is no power an would like a two or three battery solution if possible. Like one for the heaters and two together for plate supply. This radio would get a few days use per month at best . And then a few hours at a time. I would lump cells togther but when I read about it seems that the batteries are trying to be fit within the radio .I do not care about that .This could be car battery size if needed . Any help or suggestions would be appreciated . I will take my best option and be happy as always ! Thanks.!
Bill T
I made a battery pack for a RCA portable with a similar tube lineup. The pack consisted of ten 9V batteries snapped together in series for the B+ and two D cells in parallel for the A supply. The Dollar store 9V batteries are good enough and are cheap. The A cells tended to go flat sooner than the 9V batteries so maybe a couple of name brand batteries there would last longer.
Kind regards,
http://home.comcast.net/~suptjud/
"Life is simpler when you plow around the stump."
Terry , Thanks for the info ! Just one more question if you get a chance.
How long do the 9 volt batteries last roughly ? These radios must not consume much power. I was hoping someone would say there were options that did not gang them together.But when you think about it I guess the options are pretty limited. Only so many voltages made.
From the sounds of it the heater batteries are delivering most of the current . Thanks again!
Bill T
Bill,
You'll be suprised how long the 9V's will last. I have a 42-122 (5 tubes) and a 40-95 (4 tubes) that run on the same battery configuration that Terry described, and I've listened to complete baseball games with no loss of volume. They can go a couple hours a week, and have lasted as much as a year or more. The D cells are the first to go, generally.
All things considered, it's a pretty cheap way to run a radio. If you go with ten cheap drug-store variety 9V's, they'll last a good long time.
I also have several AC power supplies for these radios as well. I used some 4 pin connectors for interchangeability. It's pretty slick!
Bill
Sent from my Pentium II on the AT&T Dial Network
Bill , Thanks , between you and Terry I am sold. It just does'nt seem like it would be that way .So I had to hear from someone with experience on it. I just got done with a 1934 Ge (rca chasis ) that beat me up some .
Took a little doing to get it going .I am already beyound my limit in room for radios except at camp where there is no power . So this one is going there for weather updates mostly . I will still keep my modern radio there also . Point being I am going say I'll not start this radio right away. As you know from doing this that in couple of days I will not be able to resist !
I appreciate the infomation as always I think this will be fun to power up
when the time comes !
Bill T
I've made the battery packs for old radios with good results using dollar store battery's , about 10 years ago in the BIG ice storm in the north east I played my 1942 Zenith 7G605 Transocean Clipper 60 hours ,never failed
Thanks for all the replies and info on these battery radio power supplies.
I wish that I did not have to hook up ten 9v batteries .But that is the way to go for sure .I looked my self and found two 45 v everready.
They cost each what was paid for the radio (it was a gift).So Once I get done shoveling snow up here in New York I will get to it .That will be in April the way it is snowing this year! Thanks again for all the help it should
do the trick for me!!!
Bill
There are currently 9780 online users. [Complete List]
» 2 Member(s) | 9778 Guest(s)
