34-87 weak on low end of band
Hey all,
I am new to the hobby and I have a 34-87 that I recieved a few years ago and I am just now starting to go through it. I have noticed that the volune needs to be turned all the way up to hear the low end of the band. The high end of the band is great. You can tune in a station between 1000kc and 1700kc with the volume almost off and you can hear stations. I am using a long wire antenna that is about 25' with a loading coil so it should be resonant for 80 meters, so it should be long enough. The caps are new, resistors are new and the tubes check out fine.
Any ideas.
Thanks
**I haven't had a 37-84 in about 40 years but in looking at the schematic there appears to be only one component that would cause your problem- of course I could be wrong.
It would appear that what you are seeing is weak capacitive coupling which would make it frequency sensitive. The lower the freq, the poorer the coupling. The schematic shows part #3- "Capacity obtained by twisting the ends of two wires" on the grid of the input tube- this is the only part that sees all of the input freqs and is not part of a resonant or feedback circuit. I would look closely at this twisted pair of wires- maybe they have been unwound or run too closely to ground. You could probably replace the twisted wires with perhaps 10 or 20pF of fixed capacitance.
Pete AI2V
Thank you. I will check it out.
Also see the SERVICE TIPS section of my site for additional info on the 80, 81, 84, 37-84. The 37-84 is essentially the same as a Model 84. See these Tips as well.
Gloritone 27 Radio
Restoring Philco 96
Restoring Philco 96
Restoring Philco 96
Restoring Philco 96
Nice find! I hope it completes your console.jrblasde — 08:45 AM
Gloritone 27 Radio
Hello john, That, is the first time I have have seen or heard of that brand and model. Welcome to the party !! Sincer...radiorich — 08:08 AM
Thank you! I’ll probably use the half-round molding and tone it to match the original. Thanks for the replies!Max T — 06:34 AM
Gloritone 27 Radio
I'm kind of late to this thread, but Buzz1151 has a 3 part restore series on the model 27: A little bit of extra t...Eliot Ness — 05:48 AM
You can get half-round moulding in various diameters at any home improvement store. That way the flat edge is uniform. ...GarySP — 12:03 AM
42-345 Resistors
Great comments. I have a tinkering bench at my office, and that's where Little Phil is right now. I will have to comb ...proftrussell — 11:12 PM
There are currently 1532 online users. [Complete List]
» 1 Member(s) | 1531 Guest(s)
