Philco 60MB Dial Lamp
Hi anyone help me?
I need a new dial lamp for my model 60MB
Can anyone tell me what type I need and where I can get one from?
R/S should have it . It's a 6.3v screw in base lamp @ 150ma or 250ma. Don't remember the # off the top of my head.
#46 is what you need. Icon_smile
Don't forget Chuck's handy-dandy bulb cross reference here:
http://www.philcorepairbench.com/lamps.htm
Thanks Ron didn't know therewas a bulb cross reference
dave
Philco 91 Tuning Condenser
