Model 84
Anyone aware of a production change where capacitor #32 was eliminated from the circuit? I have one that shows no signs of it ever being mounted on the chassis.
Hi,
Nothing in any of the pertinent Production Change Notes mentions the elimination of that bakelite block (0.015 uF).
It's a bypass cap as far as function, so I'd add it back. If you can't find a suitable bakelite block, then mount a 2-point terminal strip there to mount the new cap.
I assume the screw mounting hole is there in the chassis between electrolytic cap 29 and bakelite block cap 28, inline with the 80 tube socket if you want to restore the chassis to original.
The note on Ron's schematic http://www.philcoradio.com/tech/images/84.jpg indicates that the cap was only used in early production.
Kind regards,
http://home.comcast.net/~suptjud/
"Life is simpler when you plow around the stump."
Ah, yes Terry. Forgot about that Tech Note of Ron's. Good catch.
Thanks guys.
Philco 91 Restore Code ??
No, that cannot be the 47. The 47 is a regular backelite block cap. Look at the chassis picture, it is shown there. Rig...morzh — 01:45 PM
I have changed the title of this thread from Philco 91 Schematic. I have gone through most of the cap replacements. I...dconant — 01:26 PM
Here is an online transistor substitution site… Ron462ron — 08:44 AM
One way to repair a broken wire on a coil is to take a copper strand out of some 18 gauge electrical cord, make a &quo...captainclock1988 — 12:55 AM
Hello Tim, I once had a Jcpenny 13inch tv /monitor built by NEC come into my repairshop it would start acting up at tim...radiorich — 10:59 PM
Restoring Philco 96
Mike; The last time I took a potted condenser can apart, and it was maybe 1/4 the size of the one in the model 96, I ...Arran — 10:56 PM
Compatible crts
Bob Andersen — 08:58 PM
One way to repair a broken wire on a coil is to take a copper strand out of some 18 gauge electrical cord, make a "...Arran — 08:41 PM
Restoring Philco 96
There are currently 5310 online users. [Complete List]
» 1 Member(s) | 5309 Guest(s)
