Philco 71-125 Operating Instructions
Ron,
Saw the post regarding the Philco 38-116 operating instructions. I have a scan of the operating instructions for a Philco 71 (125 series). I scanned it a long time ago at 300 dpi. It's only 2 pages long. Let me know if you want to post it on your site. I also have a scan of the original tag that was on the radio when new (says model 71B).
- Geoff
That is a great idea!
I do; yes, I will post this as well if you send these scans to me. Thanks!
Ron,
I just sent the first page and it looks like it went through. However, the second page did not go through. I got an error message saying the file size was too big. Please send me your e-mail address through a PM and I will send you the rest.
- Geoff
Email sent.
Remaining images sent.
- Geoff
Received them (late last night - did not arrive home from Cincinnati until 8 pm EDT). Will work with them and get them posted when possible, and notify here when done. Icon_smile
Thanks, Geoff!
Philco 91 Tuning Condenser
