Silvertone Model 7048
Need somehelp with the pushbuttons. Finished with chasis and plays well but can not use the buttons. thsy will not move tuner and I am notsure if some mechanical parts are missing. I have the schematis(2) but they give no information of buttons. Any advise will be greatly appreciated.
Vaguely remember working a on Silvertone like yours with same problem. Its a mechanical system. It's pot metal I'm sure and likely an actuator has broke off.
Thank you for the reply, and that is the problem.
