37-610 Volume Control
Hi all,
I've a 37-610 that I bought awhile ago. It's been partially restored and playes quite well with one exception. The volume control is very intermittent to the point of being annoying.
My question is can the pot be cleaned? Taken apart. I'd hate to have to replace this. Are there any guides on the Philco Repair Bench that get into this?
Appreciate your help and assistance.
73 de,
Gary/N9VU
n9vu Wrote:Hi all,
Fixed it, thanks for the response, LOL.
73 de,
Gary/N9VU
There are currently 9812 online users. [Complete List]
» 2 Member(s) | 9810 Guest(s)
