Philco 42-323 dial scale
Purchased a model 42-323 Philco radio at a garage sale. Radio is in real decent shape except the dial scale is peeling and needs to be replaced.
There isn't a repro for this dial scale. Radio Daze said I would have to send in my glass for them to make one at a cost of $36. Usual cost is $27.
There is a repro for the model 42-327 glass scale. I saw a picture of the 42-327 on E-Bay and the glasses looked the same. Are they the same?
Would like to match the old glass close to perfect as possible.
Thank You very much for any help.
etsojourner
Looks like they have coverage but the grafics look to be a little different.
7estatdef, thank you for your observation. In the meanwhile hopefully there is agood used one somewhere.
etsojourner
Philco 70 antenna lead
Thanks Arran; I don't even know what a double conversion is, but i do have a good friend In Nova Scotia that would k...Dan Walker — 07:01 PM
Dan; I've seen some Marconi sets like that before, one was a console though I'm not sure if it was a model 86. It's a...Arran — 05:09 PM
Milkjug plastic? Whatever is chosen for the spider, the material must be compatible with popular adhesives... Th...Chas — 05:05 PM
There are currently 3607 online users. [Complete List]
» 1 Member(s) | 3606 Guest(s)
