Philco 80jr alignment procedure.
Threads: 567
Can anyone point me to 80jr alignment procedure? Especially the regent part?
I also have some motor boating when the radio is warming up. Would like to make it clean.
Threads: 268
http://www.nostalgiaair.org/PagesByModel...013843.pdf
See last page. Try turning the sensitivity control to the left a little.
Threads: 567
Hey Terry, thanks, I have this one and I thought there might be some "in-depth" procedure with explanations outside the Rider.
Specifically the motorboating bothers me though it only occurs for 1 sec during warmup.
Still, its presence is a testament to my ineptitude and so I, being my own harshest critic, keep calling myself names due to that.
Usually it is due to inadequate decoupling in multistage schematics, that allows radio and audio stages couple, as I remember from transistor radios, or leaky AC-coupling caps, or too high a value for grid leak resistors, but the radio is fully recapped and reresistorised.
Have to think.
Threads: 268
The alignment on these 4 tube set is somewhat critical and will have drastic affect on the performance. Considering what they are they work pretty well when they're. all tuned up and in good working order. I would suspect that what you have isn't an alignment issue. Have you tried switching the #36 tubes around?
ps Still want to get together
sorry I dropped the ball on that.
Threads: 567
Yes I bought the tested ones. Thn again, as you remember, I don't have a tube tester.
I've been busy lately hunting down one. I have for radios, all working, with untested toobs. Time to shell out some dough, bite the boollit, and get something decent.
I don't want to do too much messing aound before I make sure the tubes are OK.
Threads: 18
Tell us what you need, many of us have more than enough and will share/contribute . Just might take a day or two for us top dig through the ruins to find.
Threads: 567
Thanks guys, appreciate the offer.
I've just bought Hickok 600A, supposedly calibrated.
As soon as it arrives, provided it is intact, I will test the tubes and then I wiil know what I am up against.
Threads: 268
You could try hook a jumper from the grid cap to the chassis to see which stage it is.
Threads: 567
I think I know which one it is  . After all, in Jr there are only so many of those that can do that.
Threads: 268
Also check rivets that are used for ground connections.
Threads: 567
Hey guys,
I am bat at Philco jr, doing alignment.
Two questions:
1. Different schematics in the Rider show two different IFs, 450Kc and 460kc.
The alignment procedure at the end says "460".
Which one is it?
Well, I seem to answer the second question myself so I've deleted it.
I need that plastic socket for the nut.
Threads: 268
Go with 460kc. A cheap plastic pen with the inwards removed, heat the end with a heat gun and then push it over the adj nut.
Threads: 567
I did go with 460kHz.
It works better than it did before - before I got only one local station, now I have three more, which is about the same that my Zenith receives with the same antenna.
Oh, and I did defeat the motorboating.
I looked through, saw nothing really that could do that as all I needed to replace I did, so once I adjusted the IF and the scale, I just did regen. sensitivity adjust, and the motorboating disappeared (although it only was there for 2 sec. during power-up). I guess it was the regen all the time.
This is my thread on 60 from 2016.
I had to rewind the osc coil, and I actually counted the turns and then rewound i...morzh — 03:34 PM |
Yes, Mark belongs to the same Michigan Antique Radio Club that I do. I suspect that the oscillator coil is in need of a ...Radios1340 — 03:10 PM |
Yeah. I am dreading the thought of what to do with all my consoles when I will no longer be able to move them around.
I...morzh — 02:51 PM |
Cool gadget, Buzz.
I took me a couple of second to undestand that that oscillating thing makes the wire to spool correc...morzh — 02:50 PM |
My back hurts already, you could build a house with all the wood. PaulPaul Philco322 — 02:49 PM |
Part 4 of this series now uploaded
link below to anyone interested
Buzz — 02:39 PM |
Welcome to the Phorum, Radios1340! The oscillator coil on the 60 is a common culprit. I just bought a 60B (June 1934) ...GarySP — 02:33 PM |
Yes, standard alignment procedure. I can get the minuscule tone to vary when adjusting the trimmers. But you almost have...Radios1340 — 01:40 PM |
An imposing-looking radio, for sure.morzh — 12:43 PM |
Model 60 struck again :lol:
Welcome to the Phorum!
Above is the article on Model 60. Could be of some use.
Now...morzh — 12:38 PM |
There are currently 10600 online users. [Complete List] » 3 Member(s) | 10597 Guest(s)
