46-d10a dynamic reproducer
Anyone know where I can get a dynamic reproducer for a 47-1209 ?
I have tried several sites but no luck
Correction 46-1209
This question comes up from time to time.
The original "dynamic" (magnetic) cartridge has not been manufactured in several decades. To complicate matters, the originals were often damaged by owners who stuck steel needles into the cartridge, in spite of being warned in Philco literature of the period not to do so, destroying the cartridge.
Steel needles have a slightly larger diameter than the proper stylus for this cartridge,,,just large enough to damage it beyond repair.
And, once damaged, the cartridge cannot be fixed.
An alternative is to use a modern magnetic cartridge, connected to run in mono instead of stereo, with a 78 rpm stylus. Tracking weights may be an issue, but this can be overcome.
Dan; I've seen some Marconi sets like that before, one was a console though I'm not sure if it was a model 86. It's a...Arran — 05:09 PM
Milkjug plastic? Whatever is chosen for the spider, the material must be compatible with popular adhesives... Th...Chas — 05:05 PM
Mike; I would not use plastic from a milk jug for a spider, first it's polyethylene/polypropylene which resists most ...Arran — 04:56 PM
There are currently 8188 online users. [Complete List]
» 1 Member(s) | 8187 Guest(s)
