need info (schematic)
Hello all of you.
I have a philco console radio i can't find a schematic for
The thing is is it uses odd tubes that the chassis and code are not found with (philco work bench guy)
there is no other info on the chassis:
chassis 53
code 121
bc,sw @31m, 25m,19m
bass on/off switch
tube lay out is
6j8, 78e , 6j5, 6f6, and rectifier 80
Its a canadian model
I need a schamatic or one that is close with those tubes perhaps
Did you try Dave at Just Radios?
O ya , it was Dave from just radios that said the above NOT at philco radio bench , sorry my bad.
Dave said the tube sounded strange for that model, but the sticker on the cabinet says that those are the tubes it comes with.
That tube lineup is unusual. Tried RMorg with no returns. Any thing else at all that would help identify it? The 78E is an unusual ident. Did the tube idents come from a print in the set or the tubes themselves? How about some pictures?
Ya i can get some pictures. All tubes are labeled in the console like that and no substitutions have been made. The chassis is also stamped with those types. The 78 is the auto volume control.
how do i upload images?
These threads tell how to upload images to the Phorum:
http://www.philcoradio.com/phorum/showthread.php?tid=29
http://www.philcoradio.com/phorum/showth...p?tid=4371
Ok thanks Ron for such a quick reply. Um, i dont have a site right now, but i could email a photo or two , rickd. My mail is under my profile, send me yours.
Philco 91 Restore Code ??
Philco 40-120C Restoration
RCA T62 is playing.....
Philco 89 indicator light.
Thank you Rod.  Hello MrFixr55. Thank you for the long reply. My radio is the 121 version (1 speaker) and I am aware ...dconant — 06:36 PM
Your 8 watt transformer is good, the 42s produce 6 watts and you won't be sending maximum volume to the speaker anyway. ...RodB — 05:54 PM
There are currently 3511 online users. [Complete List]
» 1 Member(s) | 3510 Guest(s)
