dial cord
I have a model 19b with worn spot that slips from about 1100 to 1200 it looks worn there to it has a biger diameter than most dial cords what can be used to replace it?
Thanks
I like to use rubber o-ring material.
Cut about 1/2 inch short and superglue it together.
Works good.
You can get it from Mcmaster Carr.
Philco 89 indicator light.
46-1201 Trip Switch Spring
There are currently 10197 online users. [Complete List]
» 2 Member(s) | 10195 Guest(s)
