Canadian made 25-40 cycle A.C. Philco Radios
... received my latest eBay purchase. Luckily, I got it cheap!! I bought it for the "shadowmeter escutcheon assembly"only to complete a US made Philco restoration. The metal chassis label is stamped (made in Toronto) model 38-09C. The cabinet paper label says it it a model 38-9C. Got the hard to find shadowmeter escutcheon assy I have been searching for, and all the internal shadowmeter assy is intact also. This radio is the old (25-40 cycles AC) as opposed to US 60-cycles on the AC line. The seller advertised the radio in working-condition in his eBay ad, but after close inspection under the chassis, I dont see how this radio could have been working at all, in the past 60 yrs period!! Doesnt really matter cause I bought it for a "parts only" Radio. If it worked as advertised, it probably didnt take long to "smoke", ( another reason to never plug-in vintage radios before careful servicing)!! I am wondering if the seller was telling the truth about his eBay listing this old Radio as "working, w/ no hums"!! Is Canada still operating on 25-40 cycles on the AC line these days?? TR
Texasrocker Wrote:I am wondering if the seller was telling the truth about his eBay listing this old Radio as "working, w/ no hums"!!
I have found that most eBay listings that state a radio "works" usually means "the tubes and dial lamp light up." Icon_confused Icon_rolleyes Icon_evil (To be fair, there are some honest sellers out there, though.)
Texasrocker Wrote:Is Canada still operating on 25-40 cycles on the AC line these days?? TR
As far as I know, no. I think they too have switched over completely to 60 cycle AC.
Hello Ron, I figure Canada must be on 60 cycles AC now also!! After checking the orig 25-40 cycle orig power-trans on this Canadian made Philco, it is "fryed". I bought Canadian 37-09 cheap (same cab as US 37-8 model), full shadowmeter assy fits perfectly into my retro-fit project (37-610B) cabinet, but will have to sub a new modern PM type spkr instead of orig Philco spkr. The shadowmeter takes up too much room for orig spkr to fit over the top w/ shadowmeter assy in place inside 37-610B cab. Will have to retrofit a new spkr "baffle-board" to use a smaller pm spkr, and sub a wirewound resistor for old field-coil resistance. Will also have to mount the orig Philco spkr trans where it will fit. My orig 37-630 (6-tube) chassis w/ 3-gang tuner, should make this a great receiver if everything works out. Talk about a "retrofit" from H_ L, this is a "doozy"!! At least I am trying to save Philcos that would have been tossed otherwise!! I figure Canada must be on 60 cycles AC by now also!! No wonder if the seller plugged it in to make his eBay post, it took-out the orig pwr-trans. Funny the seller didnt mention "anything" about "smell" in his eBay listing!! (hee hee) Oh well, I got a shadowmeter escutcheon out of the deal. Those are hard to find. Nice 37-8 (US type cab), and a blown 25-40 cycle trans to-boot!! I may put another Philco (US 60 cycle) ac trans on it, and rebuild it also someday. Randal
Hi its Canada and we are on 60 cycles ac.
Hello
I have a 25 cycle AK that I have used on 60 cycle for several years with no problem. It is my understanding the 25 cycle transformer is constructed with more steal to operate cooler.
Hello joseph, Here is the one that I use made by Vishay part no. VY2103M59Y5VS63V0. Anyway both Digi-Key and Mouser ca...radiorich — 01:34 AM
Silly me, you are right! I read and wrote nF, but was thinking pF.jrblasde — 10:48 PM
0.01uF and 10nF are the same capacitances :lol: Its the rating. Yours are rated to 500V and the Y2 are up to 300V. Obvi...morzh — 10:41 PM
You’re right, yours are much smaller. I must admit that I ordered these without much regard to size. I ordered them back...jrblasde — 10:29 PM
What should I offer?
Thanks, that makes sense. I searched Hepplewhite on Google, and saw some fancy dining chairs.jrblasde — 10:23 PM
My memory had not failed me when I was writing about those inductances. I found them, both 5.6mH and 10mH, both small ax...morzh — 10:21 PM
Joseph, Yes you could do that too. But why did you choose to buy these conspicuously large capacitors? 10nF Y2 caps sho...morzh — 10:02 PM
Thomas Sheraton gave his name to the style. That is others in 19 century took his name and assigned it to the style. G...morzh — 09:59 PM
Excellent point! Thank you, sir.jrblasde — 09:58 PM
Hello Joseph, That looks great only thing I would make sure is that screw has good clean area where it contacts the gr...radiorich — 09:50 PM
