Philco 40-185XF Question
Hi
I have the opportunity to get a Beautiful 40-185XF Console and will going next weekend to see it. I have seen some pictures of it and it looks gorgeous. The question i would like to ask is if this model was available with the Mystery Control??
Sincerely
Keith Jansen
Hello Keith,
I don't believe that model was available with the Mystery Control. Here is some information on models that used it.
http://www.philcorepairbench.com/mystery/history.htm
Best regards, Paul
Thanks Paul for the info.
Keith
Philco 91 Tuning Condenser
There are currently 6448 online users. [Complete List]
» 1 Member(s) | 6447 Guest(s)
