01-17-2013, 09:25 PM
I don't know about you Ron, but tomorrow, I'm off to the store and look for semichrome. Should spiff up the 38-116 cans I'm working on.
Jerry
Jerry
Philco 15DX restoration
Jerry ![]() A friend in need is a pest! Bill Slee ca 1970.
01-17-2013, 09:41 PM
It is kinda pricy, but a little goes a long way. That can has lasted me years. Look for the little 1.76 oz tube.
01-17-2013, 10:19 PM
I don't think it's available everywhere like in Walmart but some of the auto parts stores may have it. I've never bothered polishing aluminium, I've usually been content with a bright but a matte finish on IF cans and the like, which is pretty close to how most of them were when they were new.
Regards Arran
01-20-2013, 01:34 AM
I posted a video on YouTube last night about these rusty speakers and received some tips about unmounting the larger speaker cone and decided to give it a try. I removed the screws around the perimeter and very carefully separated the cone from the frame then removed the spider screw. Success
![]() ![]() The cone is glued right to the frame in the smaller speaker. I'm not sure it's possible to remove it without damage. [Image: http://farm9.staticflickr.com/8080/83975...58b4_c.jpg] [Image: http://farm9.staticflickr.com/8075/83964...c0de_c.jpg]
01-20-2013, 02:09 AM
Bob, your a braver man than me! Good luck and post pics as you go through it. I never had the confidence to remove and replace a cone, always sent speakers to someone who knows more than me about that stuff (most everyone). I will be watching your progress.
Jerry A friend in need is a pest! Bill Slee ca 1970.
01-20-2013, 10:26 AM
WOW
Ditto, you are brave, if that was me I would have screwed up that voice coil. Good work and good luck on putting it back together. ![]() ![]() Joe Bratcher near Louisville, KY
01-20-2013, 10:27 AM
Not sure about the K series (8 inch) Philco speaker, but on newer speakers with a cardboard gasket, a careful application of straight acetone will allow the outer edge of the cone to be removed from the frame. You have to apply the acetone, let it sit for 10-15 minutes, and carefully start to remove the cone edge from the frame. One or more reapplications may be needed.
Phorum member Ed Locker showed me that trick a few years ago. Speaking of tricks, thanks much for the Simichrome tip. I've been using Mother's Mag & Aluminum Polish on IF cans, but it doesn't seem to work as well on the 1930s Philco coil and IF shields that were spun permanently onto the chassis. -- Ron Ramirez Ferdinand IN
01-20-2013, 04:42 PM
Thanks for the suggestion Ron. I just gave it a try and it worked quite well
![]() Does anyone have an opinion as to what replacement cone to use ? I measure about 7.5" O.D. I'm contemplating an 8" from MAT Electronics but am not sure if it will fit properly. http://matelectronics.com/prestashop/en/...sories?p=3 [Image: http://farm9.staticflickr.com/8188/83988...d4ef_c.jpg] [Image: http://farm9.staticflickr.com/8215/83999...e9cc_c.jpg] Ugh. I'm glad I popped the cone out. This really needs to be cleaned out properly for the voice coil to move freely. [Image: http://farm9.staticflickr.com/8371/83999...dc18_c.jpg]
01-23-2013, 12:52 AM
After three days of rust stripper, the speakers are finally rust free
![]() [Image: http://farm9.staticflickr.com/8218/84076...7d44_c.jpg]
01-23-2013, 01:42 AM
As long as the center hole is small enough that you can mount the voice coil and spider to it it should work, do those have a foam or a paper hinge/surround? Or is it rubber? I too have known about the acetone trick for removing a glued on cone, actually lacquer thinner works just as well. You don't really need to let soak as long as 15 minutes, 5 to 10 is usually sufficient. You can use some strips of film negative or some other thin yet stiff plastic to shim between the voice coil and the pole piece.
Regards Arran
01-23-2013, 02:07 AM
I think the MAT Electronics cones have foam surround. I ordered a few and hope to have them by the end of the week. I was thinking I could leave some of the old paper cone attached to the voice coil / spider if needed to bridge a gap to the new cone.
01-23-2013, 08:27 PM
Now for the output transformer. A little drilling took care of the rivets.
[Image: http://farm9.staticflickr.com/8471/84100...76e5_c.jpg]
01-23-2013, 08:51 PM
All of the cones I have found so far have foam surround. I got lucky and bought several 8 inch cones on eBay a few years ago. The center holes are a bit small, but that is easily corrected by carefully cutting with a good knife. The depth is perfect for Philco "K" series speakers but too deep for Philco "S" speakers which need a shallower cone. The surround requires a bit of trimming as well to fit the pincushion frame.
You're doing a fine job with those speakers, Bob! ![]() ![]() -- Ron Ramirez Ferdinand IN
01-24-2013, 12:38 AM
Some newer speakers have a synthetic rubber surround/hinge but the foam ones are almost as common as the paper ones were. In the past there were a lot of problems with the foam disintegrating, especially the orange colored foam, you see a lot of replacement kits for sale for those types. I like the speakers that used a leather or chamois surround/hinge, they seem to be the most durable provided they were stored properly.
Regards Arran
01-27-2013, 06:19 PM
My order from MAT arrived and the cone was even better than I expected. Just a little trimming on the surround and it will fit perfectly
![]() Before I mess around with installing it though I think I'll try out the original cone. [Image: http://farm9.staticflickr.com/8363/84207...9484_c.jpg] The depth is a pretty darn good match. [Image: http://farm9.staticflickr.com/8224/84218...26fa_c.jpg]
« Next Oldest | Next Newest »
Users browsing this thread: 26 Guest(s) |
