Philco 84 Problem
I have a Philco 84 that I have re-capped and have either checked or replaced all of the bad resistors. Things were going reasonably well during alignment. I was picking up three separate stations, one on each end of the dial and one in the middle. Then for some unexplained reason things changed.
First, the only time the radio would receive is when the volume was turned completely up. There is no sound that comes out of the speaker unless this is done. This is a new problem that I can't seem to isolate. Furthermore I have no selectivity in the tuning, I get one strong station all across the dial and no others. Any Help would be appreciated.
I'm willing to bet your oscillator coil primary is open. I've restored three or four of these and they all had this symptom. It's not hard to rewind this part of the coil. Try to get the wire size close and the number of turns the same as the old coil. If it won't oscillate, reverse the connections. Remember too, that this radio needs a good antenna and ground to operate. It was Philco's cheapest offering at the time and while it will pick up all the local stations and sound pretty good, it is not a DX radio.
Steve Chambers
Warren, Ohio
Hello mike, Nice job hopefully it works and I am sure it will. Sincerely Richardradiorich — 09:15 PM
Hello Peter, I am glad you got the radios and I too have that same zenith in my collection ! I am also waiting for the...radiorich — 08:52 PM
So, I sat down, and first tried 40 AWG wire. It broke quickly. I retook diameter: this one was 0.05mm whereas the one I ...morzh — 08:24 PM
This is the replacement guide for transistors by GE parts. So, GE-3 is your power replacement for AR14 Just ...morzh — 04:57 PM
Philco 91 Restore Code ??
How do I know if AVC is OK? For the compensator cap I settled on 330pf. Its much closer now and close enough for me. I ...dconant — 04:46 PM
If the small signal ones, take any Ge transistor with unity gain good enough and Vce max 30 or so V. For the output....y...morzh — 03:43 PM
Yes, Michael. This winter I repaired this Westinghouse, RCA 121 and Zenit 5S29. All that remains is to veneer the Zenit ...RadioSvit — 03:28 PM
Thank you. I have one board completely de-populated. Just looking for the correct values. I'll let you know. Still h...R3Sons — 03:13 PM
Is this the one from the Fall Kutztown 2023?morzh — 02:59 PM
If it does not get narrower with strong signal and your AVC is OK, it could veru well be that the shadowgraph's magnet i...morzh — 02:58 PM
