PT-28 Question.
About what year did they come about? It's a PT-28 Code 121.
Thanks
Rob
Hi Rob
It was introduced in June 1939 as a 1940 model, and remained in the Philco lineup through the 1941 season.
http://www.philcoradio.com/gallery/1940c.htm#s
Thanks Ron.
Mine is not as nice as the one in the gallery, but not too bad.
I have a few more radios to finish before I start on this one.
Rob
