Philco 38-62 question
Does the 38-62 have photo finish on all sides or just on the front?
Kent
Just the front.
Thanks, Ron.
Philco 630csx power cord
Model 27-84 BUZZ?Humm?
There are currently 1509 online users. [Complete List]
» 1 Member(s) | 1508 Guest(s)
