voltage on tube heater 46-350
Threads: 9
City: Jasper Arkansas
newbie here got the old girl working by recapping and replaced rect tube am concerned about the voltage diff from the 40 till now should there be a problem with raising the voltage from 115 to 120? i figure it may be hard on filament heaters
Threads: 268
Hi Mountain man and Welcome to the Phourm!
Wouldn't lose any sleep over the filament voltage. (Tubes with a cathode have a heater. Tubes without a cathode have a filament).Some of those 1.5v tubes have to run with 1.5v or a little better especially the 1R5. If you have any other questions you may want to start your own thread on the matter. It will be a little less confusing. Tnx for stopping by.
Threads: 9
thanks for the info Terry it was just that the schematic shows 8.4 on tube heaters and at 123 vac this number is over that voltage considerably.
Threads: 9
Concerned about the higher operating voltages from 1946 110 to 2013 123vac in my area, this will raise heater voltages over 8.5 volts, I read that a power resistor may be in order, what type and size? also on alignment procedure it calls for an output meter to be attached to speaker terminals is this a volt meter?
Threads: 8
City: Hidden Valley, AZ
Resistors can be used to counter high line voltages, but either a bucking transformer or Variac mounted separately is a more efficient idea. Neither of them produces the heat as a resistor in the job would.
Any AC voltmeter with appropriate range can be used as an output meter, as you are just reading audio levels on the output, after using a tone modulated signal generator to accomplish set alignment.
Dennis
Pacing the cage...
Threads: 268
To add to Dennis's comments you probably want to use an analog meter just easier to read. It will be set on the low setting for AC volts.
A bucking transformers an easy way to knock down the line voltage.
Threads: 54
I still say this 110 volt line voltage idea is a myth, unless you are dealing with DC power grids, most radios from then were calculated around a working voltage of 117 volts at least as the line voltages could very between 105 and 125 volts. If the line voltage is 123 volts that's still a little high but 6 volts high not 13 volts high. Bring it down to around 115-117 and it will be fine.
Threads: 9
does anyone have any information on component locations I see on the schematic "C"#'s. it would make alignment and part id a whole lot easier.
Mountain man
Contact Chuck and get the entire package of service info for your set, it will save you some headaches.
http://www.philcorepairbench.com/schematics.htm
Threads: 9
Thanks Ron, also I am looking at a 20 ohm 25 watt power resistor to knock down the line voltage, any thoughts?
Mountain man
As Dennis (Conelrad) and Terry (7estatdef) have mentioned, a bucking transformer or Variac would be a better way to reduce the line voltage if you are determined to do so.
Google the phrase "line voltage bucking transformer" and you should get several results on how to do this.
Also, please do not post about the same subject in different threads. This only results in confusion. I have merged one thread with posts on the same subject from another thread into this single new thread, to keep it all together.
Threads: 9
sorry just trying to get the hang it, please forgive my ignorance
Don't sweat it, we're here to help.
Threads: 92
City: Clayton, NC
If you do use a resistor I would opt for something in the 40 watt range.
Threads: 18
Yeah, would be nice to slim the voltage to filaments a bit with bucking transformer or resistor. Not going to lose much volume and might get another year or three from tubes.
Gary
I in fact did, on a 38-14, I think, where I had a speaker with the dead coil.
Well...it kinda worked. Kinda, be...morzh — 10:38 PM |
Mike, what ever happened to that plan you had to try using a rare earth magnet to magnetize the pole? This looks like a...GarySP — 10:25 PM |
RCA T62 is playing.....
Beautiful set.morzh — 09:07 PM |
Well....here it is.
The green stuff. Unfortunately, probably penetrates deep.
I opened the top layer and saw that:
...morzh — 08:58 PM |
Philco 91 Restore Code ??
:clap: :clap: :clap: :clap:
Really nice workmanship!!! Top of the chassis looks great.
Sorry about the long winded e...MrFixr55 — 08:09 PM |
Philco 40-120C Restoration
Thank you for your reply. I will check voltages on the other tubes, look at resistor 23 and cap 25, etc. If all else fai...bluecap — 07:58 PM |
Nice looking set great save. DavidDavid — 07:48 PM |
Philco 89 indicator light.
Hello Jim, I have done several 89s. The trick is to move the drum in or out on it's shaft. You will need to loosen a set...dconant — 07:36 PM |
MrFixr
Yes, it is my plan to go with 45rpm spider if I go that far.
No, the pole was not left-handed as I unscrewed ...morzh — 07:14 PM |
Change the tube. Check the tube's bias network.
Are any other tubes experience the drop or just this?`
Is resistor 23 OK...morzh — 07:09 PM |
