Need pic of LO section for 16B (5 band)
Can someone provide me a clear hi-res pic of the LO section of a 16B Code 121 (5 band), concentrating on lead dress? There seems to be some very critical lead dress in that area, and I want to make sure I have everything the way it needs to be.
TIA
Brenda Ann,
This YouTube poster (Lockemeister) has a large number of videos on a 16B restoration. Maybe somewhere in those you'll be able to stop the video at an appropriate spot and see what you need. Probably lotsa work with marginal results so hopefully someone else will have a better, higher res shot.
http://www.youtube.com/watch?v=Vgh6-NbT1HI
...and from another site this shot of the entire bottom of a chassis http://canadianvintageradio.com/wpsite/w...768%5D.JPG (from http://canadianvintageradio.com/cvrs-for...completed/ )
RCA T62 is playing.....
Philco 91 Restore Code ??
Philco 40-120C Restoration
Philco 89 indicator light.
