Philco 48-828 schematics
Please schematics, service manual of Philco Tropic 48-828
Valvulas:
7J7
7B7
7C6
7B5
7B5
6X5GT
You might try the folks at Radiomuseum. They have a schematic seen at http://www.radiomuseum.org/r/philco_48_828.html . You click on the schematic and then join to get access.
Philco 91 Tuning Condenser
There are currently 5656 online users. [Complete List]
» 1 Member(s) | 5655 Guest(s)
