Model 20 power transformer
Threads: 22
City: Acworth
State, Province, Country: GA
Ran into another model 20. Two in one month. What luck but unfortunatly this one has a bad power trans. 376V between pin 6 and 9 but only 40V between 6 and 12. Does Mouser or any other parts supply house have a reasonable facsimile that I could drop in there ? Thanks
Danny
Hi Danny
Unfortunately, no.
You will need a power transformer with a center tapped high voltage winding, a 2.5V center-tapped winding, a 5V winding for the rectifier PLUS another 5V center-tapped winding for your 71A tubes.
I would suggest you consider having Heyboer Transformer custom-wind a replacement for you, if you plan to keep and use the radio.
http://www.heyboertransformers.com/index.shtml
A new transformer for your radio should cost around $100. The advantage of having a new one made is that you can have them design the primary for 125 or even 130 volts AC, instead of the 110-115 volts that the original was designed for. This will reduce the strain of higher than designed voltages on your old radio's circuitry due to today's higher line voltages.
Should you decide to pursue this, you will need the complete specifications for your transformer - physical size, mounting, and the voltages and currents required for each winding. I'll post the transformer specifications later.
Heyboer does excellent work. I've used their services twice so far, and would not hesitate to use them again. But be advised they do not provide a terminal board as the original had, only wire leads. You will either have to adapt the new transformer into the original bells and terminal board, or hook the wires into the radio circuitry, without a terminal board.
Happened to have a 1941 Philco catalog (on PDF) handy, here's the specs of your power transformer:
5-3/8" high, 3-7/8" wide, 3-1/4" deep. You'll need to measure the spacing between the mounting holes on your transformer.
Primary - 110 volts, 50-60 cycles. (For your new one, specify 125 or 130 volts for the primary.)
High voltage - 700 volts center-tapped (also known as 350-0-350V), 80 mA DC
Filament #1 - 2.5V center-tapped, 7 amps
Filament #2 - 5V center-tapped, 2 amps
Filament #3 - 5V, 2 amps (for rectifier filament, no center tap)
Threads: 22
City: Acworth
Wow, Thanks for all the info Ron. You've done all the work for me. Now,
can I get you to pay for it too ? Darn, $100 is more than I've got to burn right
now. Oh well, It'll sit on the shelf until I can scrape up the bucks. Wish I was independently wealthy. Thanks again Ron.
Danny
Ha ha, not hardly! ![Icon_lol Icon_lol](https://philcoradio.com/phorum/images/smilies/icon_lol.gif) You're no doubt read about my misadventures of last Saturday in Old Ron's Bar & Grill about picking up a 40-201; plus confiscatory Indiana property taxes are coming due, Christmas is coming soon, ad nauseum...I have my own "no money blues" I could be singing. ![Icon_rolleyes Icon_rolleyes](https://philcoradio.com/phorum/images/smilies/icon_rolleyes.gif) So, I feel your pain.
There are a lot of Model 20 chassis out there. You might try your luck with one of those. Or, use the power transformer from a Model 96, convert the output tubes to Type 45, and put that chassis in your 21 cabinet - you'll have a Model 21 Franken-Philco.
Threads: 22
City: Acworth
I did read about your travels and was wondering why, after the thermostat was replaced, did your car continue to overheat ? How to turn a 3 hour road trip into a 8 hour ordeal. ![Icon_lol Icon_lol](https://philcoradio.com/phorum/images/smilies/icon_lol.gif) While I have your attention, I've set aside that model 20 for now and picked up a little 42-PT49 that needs some attention. Tube complement is as follows 50L6-35Z3-7C6-7B7-7A8. I haven't been able to find a schematic for it. I've checked all the usual..Nostalgia ect ect no luck. ![Icon_sad Icon_sad](https://philcoradio.com/phorum/images/smilies/icon_sad.gif) Can you help??
[Image: http://img186.imagevenue.com/loc499/th_0..._499lo.JPG] [Image: http://img129.imagevenue.com/loc465/th_0..._465lo.JPG] [Image: http://img19.imagevenue.com/loc953/th_09..._953lo.JPG] [Image: http://img169.imagevenue.com/loc1021/th_...1021lo.JPG]
Danny
Threads: 58
City: Dandridge, TN
If willing to convert to 45's, take a look at this one sold by AES (P-T143).
Specifications
Rating: 350-0-350 V, 70 or 90 mA (if 5 V winding is used with 2 A rectifier)
Windings: 5 V, 3 A; 2.5 V, 7.5 A; 2.5 VCT, 3.5 A
Mounting Centers: 2.75" x 2"
Weight: 4.6 lbs.
Overall Height: 3.12"
The 2.5 volt windings can be paralleled or you can split up the 2.5 volt string into 2 strings. Might take some engineering to use it (45 bias), but at $64.25 you can save a little (on the other hand, getting 45's may cost you the difference vs. the solution suggested by Ron).
Oh well. Maybe waiting for a junker chassis is the best way to go!
Threads: 5
City: Atlanta GA
Kind regards,
http://home.comcast.net/~suptjud/
"Life is simpler when you plow around the stump."
Threads: 58
City: Dandridge, TN
Model 20 power transformer on eBay as we speak: 250182986055
Threads: 22
City: Acworth
Davemc
No one bid on it. I sent an email and he still had it. Offered him 20.00 for it and I'm happy to say the transformer is on the way here to me...Another model 20 saved. Thanks for the heads up on the ebay posting....What a great bunch of guys on this forum. I'm so happy
Danny
Threads: 22
City: Acworth
Hi All
Just an update on that PT. Got it yesterday and just finished checking voltages. All is as expected. Got a good one so I'm going to have two
model 20's. One will be a FrankenPhilco model 20/70 but thats another story for another day. Thanks every one for the help.
Danny
Here are the links. 6TPZ and 5TPO
The speakers are good. I've tried several known good ones. I just have to fi...R3Sons — 06:27 PM |
Philco 91 Tuning Condenser
I just found a set screw. Was able to turn dial just enough to see it and loosen it. I have it off now.dconant — 06:14 PM |
Hello,
Does anyone know how the dial plate comes off the tuning condenser shaft? The dial itself id so warped I can't...dconant — 06:01 PM |
Ron,
for the future:
1. Go to the very first post.
2. Hit "Edit...morzh — 04:29 PM |
Transistors are easy.
Or touch your fin...morzh — 04:25 PM |
Hi Mike, I believe I tried different ways to change the header for my post but no luck. Anyway thanks for changing it fo...462ron — 04:02 PM |
Since these radios operated in harsh environments (temp changes and vibration) you could touch a soldering iron to all t...GarySP — 03:18 PM |
Thank you Gary. Hi Morzh. These radios are 6 transistor radios. Sadly no tubes. Thanks though.R3Sons — 02:19 PM |
Ron
Instead of Quick reply, go to New Reply, then go to the title of the very first post, and change the title text the...morzh — 02:00 PM |
I am not a specialist in car radios.
I suspect they might use vibrators to convert 12V to acceptable tube voltages, so ...morzh — 01:58 PM |
There are currently 10221 online users. [Complete List] » 2 Member(s) | 10219 Guest(s)
