Unmarked paper caps on the early 16X chassis
There are two unmarked paper caps on the 16 chassis part number 30-4020-X that are shown on Riders but no value listed. Can anyone say what the value are for these two paper caps.
Hi Stude
30-4020 is .05 uF. Icon_smile
Philco 91 Tuning Condenser
There are currently 8985 online users. [Complete List]
» 1 Member(s) | 8984 Guest(s)
