Four tube Philco console?
Did Philco ever make a console version of one of their four tube sets like the 37-84? For some reason I keep picture in my mind that I once saw a Philco console with a similar dial set-up to my 37-84. Could be my mind is playing tricks on me though. Icon_crazy
You may be thinking of the 37-33F, which only has two knobs and a dial like a 37-84, but is battery operated. There is also the 37-33B cathedral, which looks identical to a 37-84 but, again, is battery operated.
http://www.philcoradio.com/gallery/1937a.htm#b
The 37-33 is a good little battery set. I have it in a BG cab. Built a p/s a few year ago. It uses something like a 1E7 as the audio output it's a dual power pentode wired in p/p and real rattle the 8" spker.
That's what I recall seeing! Didn't think Ohio's gloomy weather had totally rotted my brain yet. Good reference of the dial on the 37-33B above it. I THINK that is the type dial I need for my 37-84.
Philco 91 Tuning Condenser
There are currently 4149 online users. [Complete List]
» 1 Member(s) | 4148 Guest(s)
