Another yes another Model 95 cap question
What are the values of the 2 silver flat caps attached to the chassis under the 24 tube sockets?
[Image: http://antiqueradios.com/gallery/d/15482...+parts.jpg]
Can you identify the caps from this image?
Carl
Northern Panhandle, WV
[Image: http://i7.photobucket.com/albums/y295/de...630555.jpg]
Not on the photo but flat silver boxes, where I drew red rectangles
One has 2 wires the other has 1
Like where #46 is pointing and to the left of it
Not legible enough.....do they have screw on them?
[Image: http://i7.photobucket.com/albums/y295/de...112515.jpg]
These two silver boxes
Oh those...those are 0.2uF in Philco 20, for example (tin boxes).
Easily disassembled. I rebuilt mine - it was, I think, a dual one. The box is one of the two cap's terminals and is grounded.
You need your chassis pic with numbering like the one 20 has, and then just check against the BOM.
In the second post is the picture of the chassis with numbers However the caps are not pictured on it. My guess is one is cap 46 a dual .25 filament bypass since it appears to be across the filaments. The other one is a single cap however i do not know which number it is.
In Philco 20 it was dual 0.25uF and single 0.5uF.
Possibly yours have some numbering on them.
If yes - this is your source.
http://philcorepairbench.com/metalcap.htm
no numbers which is why I was asking the question.
Well, figure out where the wires go, trace them in the schematic and see the listed values.
RCA T62 is playing.....
Philco 91 Restore Code ??
Philco 40-120C Restoration
Philco 89 indicator light.
