anyone have the schematics? for 6J463 Zenith???????
Nostalgia Air has the schematic:
http://www.nostalgiaair.org/Resources/142/M0025142.htm
Carl
Northern Panhandle, WV
There are currently 10158 online users. [Complete List]
» 1 Member(s) | 10157 Guest(s)
