116x Restoration
I just finished re-stuffing the e-caps, and a couple Bakelite blocks that were noticeably shot. After that I powered up the set with all the tubes expect the 5Z3 rectifier. All went well so I powered up again with the rectifier in place and the set came alive -sort of-. I got some buzzing and whistling from the speaker. Made me feel better that the set wasn't deaf. Now to finish recapping the set before the next power up.
During the full power up the Shadow meter even seemed to function. I could see the vane moving with the sound coming from the speaker.
-Keith
Nice....I hope the pleasure is proportional to the chassis's size Icon_smile
busy re-capping today, and I come across a cap #40 on the schematic. It's value is .00125uf (1250pf). The replacement I have for it is .00150 (1500pf) will this be ok. I'm not sure if its critical to get the value of this cap as close as possible.
[Image: http://i1129.photobucket.com/albums/m501...bfebeb.jpg]
Thanks
-Keith
I think here it is OK to use 1.5nF.
Hey Mike,
Your going foreign on us again!!!! NF
We got to get together sometime
soon my friend.
Quote:I think here it is OK to use 1.5nF.
Thank, ill use what I have and hope for the best.
-Keith
I agree with Morzh, I don't think it will hurt. Let us know how it goes.
Worst case the osc won't run or it may shift the frequency a little. If it is running I wouldn't lose any sleep over it. Just reset the fq
Probably .001 mfd would work just fine. Need to do an alignment anyway when you get done recapping and recarbing the set.
Thanks all. Hopefully I will be mostly done with all the re-capping this weekend. I have found a lot of resistors that are way out of spec (+-20%) in this set. So they are getting replaced as I re-cap.
-Keith
Finished the recapping last night. Powered up and it sings. The tone switch has something funky going on with it though. When moving the tone switch the sound will squeal, and pop and carry on until you get it just right. I sprayed it and the band switch with deoxit and let it sit over night we'll see if that made a difference tonight.
I have to say from the few minutes I had the set playing that it is a very sensitive set. I suspect it will be a very good performer after an alignment.
-Keith
Tone control issue.
In two of the positions the tone control works as it should, in the other two positions the sound will squeal, high high pitch. There are two 4meg resistors that are measuring 5.2meg. Im going to swap these for 3.9meg.
Anyone have any idea what I should check? I have replaced all the caps with the proper values except the mica's.
[Image: http://i1129.photobucket.com/albums/m501...b33490.jpg]
Thanks
-Keith
I would not be too concerned about replacing the 4 meg resistors. There only purpose is to act as bleeders for the tone control caps (.01 uF and 3000pF) and their value is not critical. They prevent any leakage from building up a charge on the caps and causing a pop noise when the tone control is rotated which grounds the cap in that switch position.
Do you have a tube shield on the 77 first audio tube? It is right next to one of the output tubes and the grid cap lead is very sensitive to stray signal pickup. The grid cap lead should be inside the tube shield. Had the same type of squealing problem with a model 610 where the 75 audio stage is right next to the 42 output tube. Putting a shield on the tube with the grid lead inside cured the problem.
When you get it playing properly I'm curious how well it works?? I just picked up one and a half 116X myself. Haven't had a chance to go though it but it looks to be a really outstanding set be looking at the diagram. It one has been serviced but I'm not sure if it is going to need some more going over. So now I have 116X, 37-116X code 121 and a 37-116X code 122. Think I'm going to have to sell some sets as I'm running out of room. It's great fun!!!! I think I hear that the 37-116 is a better sounding set than the 38-116. I think I'll stop with these three although I would like to get a 680.
Quote:Do you have a tube shield on the 77 first audio tube? It is right next to one of the output tubes and the grid cap lead is very sensitive to stray signal pickup. The grid cap lead should be inside the tube shield. Had the same type of squealing problem with a model 610 where the 75 audio stage is right next to the 42 output tube. Putting a shield on the tube with the grid lead inside cured the problem.
That was the issue. i put all the tube shields on and that fixed the tone control issue along with the "birdies" while tuning. many thanks!
-Keith
New member
Hello all.  New member here. I bought a Predicta TV for my teenage son (who is into all things vintage, see attached pic...Jsmith5690 — 12:47 PM
I’ve asked if they accept PayPal as payment so that I can contest it if the part doesn’t arrive.jrblasde — 12:46 PM
Model 27-84 BUZZ?Humm?
Philco 630csx power cord
There are currently 2811 online users. [Complete List]
» 1 Member(s) | 2810 Guest(s)
