Philco 645k needs on/off volume control
Tested my volume control and it's bad bad bad, anyone have one handy or know any vendors that sell what I need?
Contact Mark Oppat and let him know what you need. He's most likely got it, or can build it.
http://www.oldradioparts.net/
Thank you very much for the tip on this vendor I have emailed him already. Hopefully he will have what I need.
Mark had my part in stock thanks for the tip.
RCA T62 is playing.....
Philco 91 Restore Code ??
Philco 40-120C Restoration
Philco 89 indicator light.
There are currently 7168 online users. [Complete List]
» 1 Member(s) | 7167 Guest(s)
