City: Toledo
State, Province, Country: OH
Working on this 46-200 and its a version where the 35Y4 has been replaced with a 35Z5, code 122. There is a cadohm resistor in this that Riders does not show. Connects between pin 2 of the 50L6 (filament) and pin 7 of the 35Z5.
Pin 7 of the 35Z5 corralates to pin 8 of the 35Y4 which would be part of the filament string. I'm measuring 83 ohms across this. Is this a good reading for this or has it drifted way out of tolerance?
Threads: 55
City: Evanston, IL
Riders most often shows the original Code 121 version schematics and sometimes in later volumes any production change notes - many times not.
Let me check the Code 122 version service bulletin when I get home and I'll get back to you here...
City: Toledo
Threads: 55
City: Evanston, IL
That candohm, R100 is the same in the Code 121 schematic and in the Code 122 version schematic - didn't change. 80 ohms.
City: Toledo
Thanks Chuck, but now I'm confused. Riders says the 46-200 is in volume 16 page 9 for Philco. That schematic has no R100 or a resistor with a value of 80 ohms. Also it shows a tube lineup of 7A8, 14A7, 14B6, 50L6, and 35Y4.
The label on my cabinet clearly states a model 46-200 codew 122 with a tube lineup of 7A8, 7B7, 7C6, 50L6, and 35Z5. The chassis is also stamped as a 46-200 code 122. So what gives?
Threads: 55
City: Evanston, IL
You have a Code 122 version. Have not seen the Riders, but it sounds like it's not correct. R100 (as called out in the Philco service Bulletin PR-1135 for Code 121 and Bulletin PR-1298 for the 122) is an 80 ohm candohm unit (filament string ballast). The 46-200 Code 121 did NOT have a 14B6 in it.
The Model 48-200 has that tube lineup in the Rider's you are referring to. There also is no R100 filament string ballast resistor in the 48-200 because the IF tube has a 14 volt filament (14A7) instead of the 6.3 volt (7B7), the difference which R100 makes up.
Riders got it mixed up. There's the confusion.
City: Toledo
Chuck, Mallorys also shows the same tube line up for the 46-200 that I have: 7A8, 7B7, 7C6, 50L6, and 35Z5. So did Mallorys copy from Riders?
Might it be possible that Philco made a mistake when they labeled this radio? Pictures of the 46-200 match mine to a tee.
Threads: 55
City: Evanston, IL
Don't know about Mallory. I did some further checking and the schematic that Riders shows as the "46-200" is actually the CODE 125 version of the 46-200. My Production Changes for the Code 125 version reflect the two 14 volt tubes and omission of R100 in the fil string.
Your set, with that tube complement, is a Code 122 version. The changes from the original Code 121 are only the rectifiers and filter cap and the addition of dropping resistors R101 and R102. This permitted the use of a PM speaker. The new three section filter cap and two resistors were added because of the field coil elimination.
Chuck
City: Toledo
Thanks Chuck. Well at least Beitmans got it right. Just downloaded the schematic.
City: Toledo
Another question. There is a 120K resistor from pin 4 to pin 6 on the 35Z5. Pin 4 corresponds to B- and pin 6 is the same point as pin 4 of the 7A8.
According to the schematic it should be either a 47K or a 100K resistor. Is there another cgange I don't know about?
City: Toledo
Here are the links. 6TPZ and 5TPO
The speakers are good. I've tried several known good ones. I just have to fi...R3Sons — 06:27 PM |
Philco 91 Tuning Condenser
I just found a set screw. Was able to turn dial just enough to see it and loosen it. I have it off now.dconant — 06:14 PM |
Hello,
Does anyone know how the dial plate comes off the tuning condenser shaft? The dial itself id so warped I can't...dconant — 06:01 PM |
Ron,
for the future:
1. Go to the very first post.
2. Hit "Edit...morzh — 04:29 PM |
Transistors are easy.
Or touch your fin...morzh — 04:25 PM |
Hi Mike, I believe I tried different ways to change the header for my post but no luck. Anyway thanks for changing it fo...462ron — 04:02 PM |
Since these radios operated in harsh environments (temp changes and vibration) you could touch a soldering iron to all t...GarySP — 03:18 PM |
Thank you Gary. Hi Morzh. These radios are 6 transistor radios. Sadly no tubes. Thanks though.R3Sons — 02:19 PM |
Ron
Instead of Quick reply, go to New Reply, then go to the title of the very first post, and change the title text the...morzh — 02:00 PM |
I am not a specialist in car radios.
I suspect they might use vibrators to convert 12V to acceptable tube voltages, so ...morzh — 01:58 PM |
There are currently 9820 online users. [Complete List] » 2 Member(s) | 9818 Guest(s)
