Philco 46-420 dial
Ive got a 46-420 and its recapped and plays just great. Didnt know this till I got it appart but someone has painted the inside of the dial. I think in hopes of wipping it off and leaving the dial numbers. Anyway dial is junk cant see the dial pointer at all. Hope to replace the dial. dont really know where to start except for donor radio.
john
Hippo? Common enough.
Model 27-84 BUZZ?Humm?
Philco 630csx power cord
There are currently 3561 online users. [Complete List]
» 1 Member(s) | 3560 Guest(s)
