Is this a asbestos chassis liner?
Threads: 13
City: Columbia, MD
I just got a old sears silvertone to redo. Upon removing the chassis i have noticed what feels and looks like asbestos. Can anyone confirm....and if so what should I do?
[Image: http://i818.photobucket.com/albums/zz105...66ff7f.jpg]
Threads: 14
City: Irvington, NY
I certainly does look like asbestos. It was pretty common in the 30's and 40's to use asbestos fiber sheet under the chassis and in the cabinet near power tubes. I have a Philco 40-120 with the same type of asbestos in the wooden cabinet under the chassis. The earliest Zenith Transoceanics also had asbestos under the chassis.
If it were my radio, I would try not to disturb it to minimize getting any fibers airborne. When working around it, wear a respirator approved for asbestos and do it over a disposable surface. It is usually recommended to thoroughly wet down the asbestos with water so it will not become airborne when disturbed.
Threads: 13
City: Columbia, MD
Im going to get rid of it. I will look om McMaster Carr and see if I can get a fiberglass weave type sheet to replace.
Threads: 563
Zenith 7G605 has the asbestos sheet also under the chassis.
Oh well. As long as you do not polverize it and start inhaling....
Threads: 54
I usually just ignore the asbestos unless it's falling apart and has become useless. Unless you do something stupid like grind it up and snort it like a certain drug that Rick James used to use, you have a greater risk of something happening while crossing the street. One way to deal with it, if it's a concern, is to encapsulate it with latex paint, it will soak into it and prevent it from coming apart.
Threads: 92
City: Clayton, NC
When faced with asbestos in old sets, I very carefully remove it from the set, place it in a paper sack, and douse it with kerosene.
Then I take the kerosene-doused-sack-o-asbestos to my ex-mother in laws house, set it down on the front porch, light it on fire, ring the doorbell, and DRIVE AWAY LIKE CRAZY before she is able to mount her broom and chase me down.
Threads: 563
Could you simply use garlic instead?
Threads: 92
City: Clayton, NC
Already tried to place a garlic necklace on her when she was asleep, but she keeps her casket locked.
Threads: 563
Drill a tiny hole in the casket and feed a small tubing in there, and run some H2S in it (that's the stuff that we produce when eating predominantly bean-heavy diet). Once she opens the lid, have your necklace ready.
Threads: 92
City: Clayton, NC
Now why didn't I think of that?
Threads: 13
City: Columbia, MD
Threads: 12
City: Nashville, TN
That's one of the thickest "A" pads I have seen.
I it were mine, I'd apply a paint/clear lacquer with a brush. and leave it in place.
Threads: 563
Paint/lacquer may not work.
The very function of asbestos is the thermal insulation, which it is excellent at.
The paint may simply burn if the heat is high enough and you will be smelling fumes that probably will do you more harm than the asbestos itself.
Threads: 11
City: Black Mountain, NC
Go to the auto parts store and by a can of high-temp ceramic exhaust header paint and encapsulate it.
Mike
Cossor 3468
GE 417A
Philco 118H
Radiola 17/100
Scott 800B6
Silvertone 6130
Stromberg 535M
Truetone D1952
Threads: 12
City: Nashville, TN
On most of the chassis I have seen, the pad was under the chassis, not much heat going downward.
If there is enough heat to burn the lacquer, then there needs to be something else in there besides a 'grey pad' of you know what.
I think the idea behind it was to help spread out the heat so you didn't have a hot spot. This is important when the pad is on the inner top of the cabinet.
Philco 91 Restore Code ??
Well, this cap you showed cannot possibly, due to the way it is constructed, be 1000pF (0.001).
It can be in tens of pF....morzh — 03:13 PM |
I have two schematics for this radio one shows the 47 block (126-226) and the other (121-221) does not. My radio does no...dconant — 02:32 PM |
No, that cannot be the 47.
The 47 is a regular backelite block cap. Look at the chassis picture, it is shown there. Rig...morzh — 01:45 PM |
I have changed the title of this thread from Philco 91 Schematic.
I have gone through most of the cap replacements. I...dconant — 01:26 PM |
Here is an online transistor substitution site…
Ron462ron — 08:44 AM |
One way to repair a broken wire on a coil is to take a copper strand out of some 18 gauge electrical cord, make a &quo...captainclock1988 — 12:55 AM |
Hello Tim,
I once had a Jcpenny 13inch tv /monitor built by NEC come into my repairshop it would start acting up at tim...radiorich — 10:59 PM |
Restoring Philco 96
Mike;
The last time I took a potted condenser can apart, and it was maybe 1/4 the size of the one in the model 96, I ...Arran — 10:56 PM |
Compatible crts
Bob Andersen — 08:58 PM |
One way to repair a broken wire on a coil is to take a copper strand out of some 18 gauge electrical cord, make a "...Arran — 08:41 PM |
There are currently 2484 online users. [Complete List] » 1 Member(s) | 2483 Guest(s)
