Mohawk products/ Philco 645K
Need some info on online suppliers for Mohawk products. Need colors for Philco 645K sides and front/bottom trim.
Thanks in advance, Vernon
Here's one source:
http://woodfinisherssource.com/
I am fortunate to have a distributor 1 mile from work.
Any of these close to you?
http://www.mohawk-finishing.com/find-a-distributor.aspx
Tim
Thanks to that link you sent me I found two within a few miles, thank you.
There are currently 6928 online users. [Complete List]
» 2 Member(s) | 6926 Guest(s)
