schematic on a 41-250
I have the one from Nostalga Air also the original Philco service data but all of it is too small to read when printed. Does anyone have a schematic that I can print and read?
maybe i need new bifocals.
Thanks
See the Schematic Info page on my site. In my info packets, the schematics are enlarged to 11x17. See the details on that page.
Happy Holidays,
Thank you very much
There are currently 8964 online users. [Complete List]
» 3 Member(s) | 8961 Guest(s)
